I would respectfully differ with those of the opinion that the bed simply cannot be twisted. That's nonsense. It might appear and seem like it would be impossible, but all metals have properties that make them stronger in one direction than another, and machine designers take these properties into account when designing a machine. But there are always compromises. And metals change as they age. Green cast iron, in ingot form, is totally unsuitable for anything requiring rigidity, so of course, subsequent processes change the properties to improve things. But there is absolutely no way to make any metal totally stable. Even special metals that are used for measurement standards are kept in special environments to compensate for their instability, as insignificant as it is. A piece of cast iron, properly designed, is cast in the best shape thought possible to compensate for its far less than perfect stability. After casting, it is processed with various stress relieving heat treatments. Then it is rough machined. Again it is heat treated. Why? Again to try and improve its stability. Then it is semi-finish machined. Likely again heat treated. Then some machines are induction hardened on the ways. And machined further. There is no way that the end product is totally relaxed and stress free. What that means is that in time, it WILL move. That's why all the instructions come from the factory regarding leveling and mounting of machines. They are almost alive, and need to be restrained/constrained in the final shape, the same way they were held in the machinery that did the final machining, whether grinding or whatever.
I realize that the theory of the three point mount is to minimize any distortion from improper mounting, and it does make things more forgiving, but you are fooling yourself if you think the metallurgy of cast iron has developed enough to create a piece of machinery that stays as straight as manufactured. Just because the bed is a complex webbing made to look ultra stiff, trust me....it still moves. Time will get to it.
