how many change gears should come with a 10f?
Thanks.
I've downloaded a couple of the docs you mentioned in PDF form. Google found em for me.
But I will be looking to buy a paper copy.tablet and laptops are OK, but I prefer a book I can open a page to and read.
Maybe I'm just getting old......nah!
You could print the PDF files until you find a book.
A word of advice if you have never worked with gear trains before allow a little play between the gears. A couple of thousandths is plenty. A piece of aluminum foil cut in narrow strips place between two gears will help with setup. Any size gear or gears can be used as ilders between the two speed/feed gears. I had to learn gear trains in high school machine shop back in the late 60's. Good luck with your new lathe, my she serve you for many years.
