I need to use a slitting saw on a project, but I only have 2mm clearance below the groove I need to make. So I am looking to make a low profile saw arbor.
How thin can I make the retaining "cap"? I like the design from Joe Pie's video because most of the cap fits into the arbor, and the retaining screw is countersunk. Is <2mm too thin for a "washer"? I assume it just needs to hold the blade in place, a lot of the "stability" can come from the arbor side of the blade (a good assumption?)
BTW, the project is plastic, so not so much tool pressure.
Thanks for your advice
PS, the groove itself is about 2mm wide, so maybe some stability can come from the thickness of the blade.
