- Jan 4, 2021
- 1,968
Honestly, this has become my go to for simple center punch pickup.
A coworker showed me his method years back and I really couldn't grasp it and didn't like it flailing around and having to reset it every time.
I've developed my own method where I run it at roughly 140rpm and I have good success.
The key to running it that slow if to lift it off of the spot quickly.
The wiggler with the pointed attachment is only rotating while you set the pointer to align with the spindle; then you turn the spindle off and use the long pointer to line up the spindle with the pinch mark. Even at slow speeds the needle point can open you up.
