Agreed on most of the comments above. A carpenters level, used carefully, should be fine to get the table top level enough.
It is going to be tricky to get five or more legs to bear evenly on the floor without adjusters.
What about adding a third sheet of 3/4 plywood under the top to sandwich the cross studs? With everything glued together it should be a very stable top. If you plan the layout of the machines beforehand access holes can be cut in this 'under panel' as required.
Ideally, with a rigid top built like a sandwich, four beefy legs located in from the corners (to balance out the span between and beyond the legs) would be enough.
