How else can I make this part?
Why not drill a hole in the center and face mill the sides to achieve the offset? You would have to start with a slightly larger block but then you could mill it down so that the hole is where you want it to be. That is possibility #17. It will take a bit longer, but can be done without a 4 jaw or using a shim.
Bob
a 1/8" shim under 1 jaw would offset 1/8" if i'm not mistaken...
mike:))
The actual shim will be much larger than the offset. Here is a diagram, showing 1" square stock with a hole 0.1" off-center, and the circle that would describe the position of the 3 jaw chuck if the jaws were pointed. As you can see, the 0.1" offset requires a shim of 0.178". Since the jaws have some width, the actual offset will be even larger. Also, the un-shimmed jaws will be loaded at an angle, which may cause them to deflect. I recommend that you either get a 4-jaw independent chuck or use a faceplate. Setting up the faceplate is not hard; just center punch the center of the desired bore, run a dead center from the tailstock into the punch mark, and clamp the workpiece to the faceplate. By definition, the hole will be bored at the marked center point.
GK1918, just to clarify, the stock sold at Home Depot is very limited. They have some round stock HRS up to 5/8 or 3/4 -inch, a few pieces if flat stock up to 1/4 inch, some square stock and some aluminum both round and flat. Oh, they also have re-bar in the fence area.
Another place to check is Tractor Supply they have HRS round stock up to 1 inch and 4 feet long. Not cheap, but in a crunch...
Daver, I didn't mean to hi-jack your thread. I just want to make sure that I made myself understood.
Does anyone try to balance off-center parts, especially on the faceplate. It seems hard to get a finish when you have to turn very slowly with very unbalanced part on a face-plate or even sometime a 4-jaw. Any hint or suggestions on this for Daver as well, not to mention myself?:thinking:
