Success! I had a 22mm x 4mm O-ring on hand and got the gearbox back together last night.
If anyone is reading this and contemplating opening the gearbox on a similar lathe, it was not necessary to remove the knobs/levers from the from cover. Putting it back together was a balancing act to get all four levers properly engaged and moving smoothly. It's all working now; just need to add oil.
