After many months I finally figured out where this lathe was leaking oil. It didn't leak while running but would discharge 1/2 teaspoon (2.5cc) of oil from the feed rod drive every time I shut it off. After a while that leaves a lot of oil in the chip tray, especially since I mostly work on small items. According to the operation manual the shaft is splined inside the QCGB. I removed the 3 socket head capscrews but there is no sign of movement from the flange either in rotation or by pulling. I put screws in the drive and wrapped some heavy wire around the heads. Yanking on the wire didn't move anything. I suspect that as tight as the screws were and the way they cracked when I broke them loose that they hadn't been removed before. The lathe is a Victor 1340GHE which appears to be a loose clone of the Clausing Colchester 13" 8000 series. This flange and shaft need to come out so I can replace the O-ring that controls oil. Any suggestions?
The manual is not a service manual so the drawing is the best I have.
