I have the 4 jaw scroll chuck for the Taig. You can grind a small bit to true up the jaws and you will be fine. I found that after truing, you can snug the jaws up on your work piece and then get it to run with little to no runout. The Taig's are nice little machines and you can do close work if you take your time with them. You said you haven't used a lathe much. Truing up the jaws will get you more familiar with the lathe operations. Also check your chuck jaws to make sure they are seated properly. I found that the soft jaws can get a little marred up if you change them frequently and this can lead to them not going back on 100% square.
