I love that video, I learned so much. I agree, honing is tricky biz and I've have better luck investing in a bench Baldor knockoff tool grinder and Deckel knockoff tool grinder and a loupe to see better what the outcome is.Tom lipton of course has a video on tool sharpening and honing.
The one attachment I don't have for the Deckel clone is for lathe bits. But after seeing this Stefan G. vid I went and made the attachment he describes for doing radius work and for doing lathe bits in the Deckel clone.Real nice grinders at a good price are a rare site in the UK , I have two very cheep bench grinders on a stand I have made, they work but I do lust after a nice Baldor style grinder. Their was one on ebay for ages, with a buy it now of about £400 that was just a bit to expensive and far away for me to impulse purchase but occasionally I would look at it and sigh a little actualy more like
I use my nice 4 inch makita angle grinder with a cut of wheel for rough shaping of form tools like threading tools. saves a bit on the dust and grit in my small workshop area. I generly use my grinders outside which is another reason I havn't got a massive lush grinder as I would then wan't some sort of extraction / grit colection system to avoid covering everything else in abrasive powder
Stu
Wow, those Accu-finish start at $900, a bit beyond my budget. While I agree with what you say about belt sanders I'd have to make some kind of rest for mine as its horizontal with no rest. It does have a 9" disk sander but the rest was garbage so I took it off. Like with honing I have a hard time keeping the angle true through the range of the stroke freehand. And with the belt and disk freehand tends to dig in on the leading edge. I get this is where superior technique comes in.If you guys want to precision-hone a lathe tool, get an Accu-finish from Glendo. You can put an extremely fine and accurate finish on HSS or carbide lathe tools and inserts with it, not to mention scraper blades. You cannot grind the radius that Stephan showed but for bringing it to a fine edge, yeah, the Accu-finish will do it. I happen to own one of these contraptions and I like it but I do not use it for honing most lathe tools; it is much faster to do it by hand and just as effective for most tools. I do use it to hone my HSS and carbide insert threading tools so I can control the geometry, though. I still need to make a fixture for sharpening gravers but that will go on the Accu-finish once I make it.
For grinding and shaping HSS lathe turning tools, a belt sander is far more effective than a bench grinder. It cuts faster, cooler, flatter and with better control, not to mention the ease with which you can change grits. No danger of a wheel exploding or having to be dressed, either. I used a bench grinder for a decade so I am very clear on which machine is better for this particular task, at least for me. You might want to consider it.
Someday, if you decide to get serious about HSS lathe tools, consider a 2x72 belt sander.
