Re: How do YOU make a "T" nut for your QCTP?
Ditto to what Frank said. :thumbzup: I'd like to add a bit as well. If you are making your own "T" make sure that the stud cannot screw in so far as to go completely through the "T". If this were to happen when you were tightening it, you could break the "ears" off the compound or do other nasty damage. On my Aloris "T" stock they left the last couple of threads un-cut or missing so it can't go through. Even if you use loctite it can come loose after a time (if not used properly) so be sure to do it right. Frank's suggestion of pinning would also be a good way to prevent this from happening.
-Ron
-Ron
