- Dec 2, 2012
- 1,788
He always complained the end mills were crap, because they died a quick death.
yeah I wonder why that was ?
Who can tell ?
Calculating chip load and IPM is for CNC machines. I never saw a manual machinist try to calculate it or care to. Dial the power feed down low and engage. Gradually increase the feed until it feels/sounds about right, stopping just shy of breaking the endmill. For all of the science in machining, it's still an art.
Sadly, owning a small machine shop in my garage hasn't magically made me a machinist. I'm working hard at it, but there us no substitute for experience. The slide rule has made me comfortable taking bigger bites than I was previously. I'd swap my little slide rule for one if you all to fly out and show me the ropes, but until then, this stuff is a bit intimidating to us noobs!There are no "tricks", if the device that you are using has no defined feed rate you would simply measure it and make note of the actual speed at an indicated speed setting, you are a machinist after all.
Measure, do a bit of math and have at it, you will not be terribly far from what you require this way.
I bought a super beautiful one from 1941....I'll have to post some pictures...vintage wash machine green plastic(?) Bakelite (?)Tha
That is a good plan, I've used these speed/feed calculators for over 50 years, they take the guess work out of (especially) milling, good for drilling and lathe work as well.
You'll either get to know the feel of a good cut, or break a lot of end mills.
I for sure won't break any end mills, but I'll take forever to machine something. I'm super careful and light with the feeds. I'm sure there are negatives to cutting too light, but i feel better too light than too heavy. Working up to the ideal chips, but it is a bit daunting. I would love to have someone with some serious skills show me the ropes...not a lot of machinists in the neighborhood. So what does a quality chip look like from say hot rolled 1018 mild steel? I know my chips are why too small.This,
Once you develop a bit of feel, you can hear, feel, and often smell; when the speeds and feeds are in the right ball park.
