- Aug 3, 2017
- 2,437
So a while back, I picked up a pair of the Windy Hill Foundry 6" machinist square castings (https://windyhillfoundry.com/) to play around with. I finally got around to starting to machine them.
I started by milling, the 'sides' on a pallet plate, then am working on surface grinding the sides.
For the 'faces' I'm going to use the same plate, then use my X and Y axis to mill the sides, which should get me as accurate as my machine is for 'square'. However, I'm wondering how to grind the 2nd face? For the 1st, I can indicate across the face and just grind it that way.
I'm not sure if I should just do the same for the 2nd face. That would make it out-of-square up to 2x the error in indicating it in. I thought about indicating the 1st ground face using the spindle-up/down, however that would only get me as accurate as the surface grinder spindle squareness. AND considering that the 'head' up/down doesn't necessarily have to be accurate in that dimension, I'm scared that would be worse than the mill.
Every one of the youtube videos I've seen seem to use some giant 'machinist cube' and just bolt it to that, and rotate the cube. However, I can't seem to 1- find one of those available, 2- convince myself this job is worth whatever-many-hundreds/thousands one of those would cost.
Is there something I'm missing here? Does anyone have an idea?
Currently, I'm planning on mounting it to an angle plate that I'll indicate in at 90 degrees somehow or another
