- Mar 24, 2013
- 48
E35o, Your welcome and it is a pleasure to me to be able to help.
There is a lot of misinformation about welding and it is easy to misinterpret information in this field.
Is wire welding with short circuit easy? Well no, the same prep is required, the proper joint design applies to short circuit mig welding just as it does for most of the manual arc welding processes. A gap is a gap and an open root is an open root and must be dealt with and only with practice and proper instruction can these procedures be learned.
The AWS code D1.1 does not have any preqaulified welding procedures for structural steels that allow any short circuit mig on steels. In D1.3 the AWS does have some Preqaulified procedures for 1/8 and under for structural steels. And limited procedures that cover steel short circuit to 3/16ths. Short circuit has 3 problems, Lack of Fusion, Lack of Dilution with the base metal and Porosity. Both you and Franko have definately proven this. The world wide web will tell you otherwise. I mostly weld under ASME procedures. At work we don't weld any steel short circuit 1/8 and over. There are lot better ways and much better processes that don't have the lack of fusion, dilution and porosity problems using the same welder with just a change in gas and wire. And these processes are faster and easier.
I don't own a pulse welder and use a lot of spray arc with 90/10 and 98/2% oxy. For out of positition welding I switch to e71t-1 flux core gas shielded 75/25, which means I carry 3 shielding gases. Sometimes have 5 or 6 other gas bottles to satisfy the full capabilites of all my welders, along with all types of wires.
Pulse eliminates a lot of this. One gas for steel. Two wires for steel. Amazing.
At work I use the same welder you have. We use 2 gases and 2 wires for probably 95 percent of our welding. From 18 ga galvanized sheet metal to as thick as you want to get on a36 and some 514 steels under a 1/2 inch and T1 steel to one inch. I weld aluminum and a lot of 3 and 400 series stainless with two more gases. One machine that pretty much does it all.
