- Mar 26, 2018
- 2,725
This thread has (re)taught me how expensive being a carbide shop is! $125 for an insert that I'll probably overfeed and destroy the first time I use it, then only use for 1 hole is crazy. I'll stick to grinding and burning HSS thank you very much!
I should have been more clear. The boring bar and clamping hardware would probably be $100. The inserts are around $15 each. Really nice quality tools. I've used their grooving line since changing inserts repeats the tip position and length within a tenth or two. Very impressive.
I purchased these tools for a paid CNC job where not needing to worry about offsets or grinding tools in the middle off the job was valuable to me.
