- Nov 15, 2016
- 943
Take a piece of rod of the length radius you want and make the ends into points. Make a center punch mark on your headstock and another on your cross-slide. Place the rod between the two and put some pressure on it. As you wind the cross-slide while maintaining pressure on the rod the tool will describe an arc the radius of the length of rod.
Very quick and easy for a concave surface. If you want a convex surface work off the backside of the cross-slide and a stop like the tailstock. I'll see if I can dreg up an old article showing this.
