I have a commercial Euler's Disk.
is one of a zillion youtube videos if you have not seen it. Yes, have made alternative disks to the 3"X.5" steel one it comes with. (Same general effect, but slightly different sounds, timing, visuals, and ending accelerations) But now I want to make my own base--the one it comes with is not as strong/stable as I'd like to try (it is not rigid steel).
(If you spin a disk on a flat metal plate the disk tends to wander a-ways, and as these are pretty heavy and energized pieces of spinning metal when they come off the steel plate they knock stuff around and dent normal household items (don't ask))
So, I want to put a gentle concave curve (think a telescope mirror shape, but I don't need anything near that sort of precision, a section of a sphere, a very shallow bowl) into an 8" diameter (by .5") steel base disk. I can make the disk (I use a 2" diameter by 1" long stub screwed in from the back to grab with the three-jaw.) This concave bowl shape keeps the heavy spinning Euler's disk safely spinning freely in a constrained space.
I have measured the sagitta from a 6" ruler, and it being .082" indicates I need a radius of like 55". I have a PM1040V lathe (and PM25MV mill).
My question--any ideas how I make a steel part like this? Geometrically I do want the shape to be a section of a sphere.
Thanks for any pointers as to where this may have been discussed before too.
-Bill
-Bill
