Drilling holes is not a precision operation. Drills only remove metal. Drills do not go straight. Drills do not stay on the axis they start on. Drills do not drill a hole the diameter of the drill. Drills are only for removing metal. If you want the hole to be in a specific place, or to a specific diameter, or even better to the right diameter AND in the correct place, both at the same time(!), then you need to pay a lot more attention than just punching a hole with a drill. An under sized drill, then boring bar followed by a reamer, or a precision bored hole following a drill, are the best ways to get there.
