- Dec 18, 2019
- 7,428
I have a piece of stock that I'd like to use part of. Namely the outer part. Trying to make a collet wrench, using the thread "Operation spanner wrench". It seems almost criminal to bore out the center, turning it into curlicues. I'll do it, if I have to, but it just seems wrong to waste it. So is it possible to cut out the center with a parting like tool, but from the facing direction? Piece in question is a disk of 1144 steel, it's 3.75" in diameter by 1/2" thick. I'd like to cut out a 2.5" plug from the center. Maybe I can use the plug for something. Sure can't use the swarf for anything good.
Any suggestions on how t do this? I have 1/8" and 0.040" parting blades I could use, as well as HSS bits.
