- Feb 1, 2015
- 9,992
Single point threading is the best way to insure that the thread axis is coincident with the rod axis.
To help square die cut threads on the rod, I will sometimes turn the tip of the rod to the root diameter or slightly larger for the thickness of the die. This gets the cut off to the right start. If threading in the lathe using a die, I will back the jaws on my tailstock chuck and use the face of the chuck to square the die. Also if using the lathe , you can notice if the diestock is wobbling when you first start to thread and exert a little force to correct it.
For threading using a vise, there are diestocks which have three adjustable plates which act much like a follower rest on a lathe to guide the rod in the die. My ancient Craftsman diestock had this feature.
