Got them. Nice! Thanks! I really NEED this now, see next message:
The bearing surfaces for the needle rollers is usually a precision one both on the shaft and the housing the needles should also be a really good fit . The carrier cage should have no oval holes or over sized ones & very little end float along the needles length
I'm running several scenarios through my mind to sort out my well worn ( no lubrication in times past ??) top pulley cross shaft & both of the phosphor bronze bearings which get oiled at the start of every session of work and several times in between start and end of a job .
I'm just thinking out loud here , anyone can come in & make suggestions that may improve things .
As I don't have a mill , just an ancient lathe and a small well worn drill press I'm beginning to believe I'll go for buying some drill rod of the correct size for the shaft as it saves trying to turn anything accurately over any decent length .( mine is about 19 inches long )
Then make a set of two identical simple steel carrier tubes ( using some tube I already have perhaps if I'm lucky ) to take the new sealed ball bearing outer bearing size .
Perhaps locate the shaft with circlips either side of the bearings and also locate the bearings in the carrier tubes with circlips ether side /end of the tubes . If you use four bearings on the shaft (one at each end of each tube ) the radial and end loads will be next to nothing so should allow a fairly thin wall (1/4 " ??? ) around the outer bearing edges , this would negate you having to turn down a pair of big billets of steel . Of course using Locktite to glue the bearings as well in the oil free tubes as well would be a good " belt and braces " solution as well )
Setting the complete carriers & bearing ...
All you need is a slightly shouldered end on all the bolts to locate into a small holes drilled in the tubes as there is not going to be a massive load on the shaft , you could even weld drilled out nuts to the tube & use those for the locating holes or drill and tap the tubes .... Locktite a short head drilled bolt in the holes ( short enough to clear the shaft inside the tubes and use the drilled heads as the locating slots . It would be fairly easy to accurately scribe the diametrical lines where the holes go .
