- Apr 12, 2013
- 562
I was looking to cut some long straight grooves in a tube (AR tubular handguard to be exact, anodized aluminum). I've seen several people lock the headstock and run the carriage back and forth with a bit rotated 90 degrees in the tool holder to put shallow grip grooved in handles and the like. This cuts shallow grooves horizontally down the length of a small part. with the length and number of grooves I am looking at, hand cranking is less attractive.
My tool would be a V ground large radius (1/8" to 1/4" radius???) nose square bit to give me a shallow rounded bottom groove.
My question is if I can pull (unlatch) the bull gear pin, leave back gears disengaged, and use the feedscrew to run the carriage back and forth. I would lock the bull gear with the lock pin, and use the index holes for indexing as designed.
Are there any pitfalls I need to watch for, like chatter and workpiece flex? I think I have holding the tube worked out, but it will be near 12" long and only supported on the ends unless I break out the follower rest.
