- Mar 26, 2018
- 8,645
I don't know the equations involved but with a hydraulic downfeed it's more a matter of blade downward travel per unit time rather than static pressure
because if the blade was not being driven eventually the full weight of the saw would bear on the blade and probably break it, so you are essentially clearing a path for the teeth to drop into, bit by bit...I suppose the effective dynamic pressure could be measured somehow-? Maybe a pressure gage on the table with some sort of hinged workpiece? Hmmm perhaps even measuring the temperature rise with an infrared gun?
Mark
All good points. As the blade comes down the geometry is changing and the values along with it. The spring seems like more like a lifting aid to me. The arm is almost neutral at about 70 degrees and falls with increased force obviously.
A challenge to say the least. New equipment works great, this old saw is a far cry from new.
This is a pic of the saw, just not my saw, pretty close though. It weighs in at 680 pounds. 6X12
