I don't know Paul, I've never put anything but WD-40 on my machines for the last 30+ years and they look pretty darned good. Maybe my shop is just drier than yours.
Guess we'll just have to agree to disagree on this one. :thumbzup:
Tom
Tom
I would have to think, yes your shop may be drier than mine, but more importantly is the area one lives in. I live in the north. Cottage country you might say. The area is full of lakes and lots of moisture.
This alone is not a good combo for WD40. The WD will attract the moisture, and when it dries up, it will leave rust. As said in my above post, The guys that use it on a regular basis, it does help some. But, if you were to spray down your vices , or R/T and such, and put it away for the long term thinking its protected in a moist envirment, you will find it rusting.
You say you use this product enough, your purchase it by the gal. That tells me your allways on top of the rust control, and must be spraying your stuff down regularly to keep it wet. Users doing this will get away with it for the most part.
I do agree on a few things though.
It does work well to clean grimey machines. Because it is full of solvents. It allso works well for cleaning your hands of grime, solvents again. For things that sqeek, its thin enough to get in there, but again, its not long lasting. How many of us have used WD on a simple task like a sqeeky door hinge, only to have the same hinge needing more WD a short time later? How many of us have spayed on WD on anything, and in a short time,its dissappeared! And the cycle continues, reapply more WD40.
At least with oil,it has lubrication qualitys, and does not evaporate like WD40 does.
Keep in mind there are those guys that will spay down a machine tool, and put it away for the (long term) Possibly 6 months or more, over the winter perhaps, in a un heated garage. These guys should be aware that WD40 will not protect there tools over the long haul. Those of us that visit there shop regularly, and respray the tools down, then yes. they will get away with it. For all the tooling I have, I have 7 tool chests, and several cabinets full of stuff. I could never keep up reapplying WD,,,Its oil for me.
Paul
