- Nov 12, 2017
- 391
re: Flatness of parallels.
That no visible light penetrates junction of one to another is misleading. Width of bar width acts like a window blind; light may penetrate undetected, until you get perfect eye alignment to the 'joint' and light source. Plus, fluorescent lamps do not have the wave length or beam of an incandescent bulb.
And wider the bar, the more perfect it appears.
The straight edge profile most adept displaying lack of contact is the 'knife edge' variety. The name is misleading, actual contour is an apex with a small radius. That maintains its alignment throughout the length; [ie] the apex, radius, angle and tangents do not vary in relationship.
In lieu of a knife edge, try a drill or reamer blank. What "was" straight might prove disappointing. Another method is with 3 feeler gages; this works with wider material. Simulate the Airy points [https://en.wikipedia.org/wiki/Airy_points] dividing length by .57735 to locate two of the shims. use the third to prove openings prevail equally; middle and ends.
