- Jun 18, 2019
- 15
I'm tackling a project that needs more precision than my wood shop tools can deliver (small vibrating solenoids). So -- down the road to precision, I:
* made three straightedges which show no light when joined (backlit with a window in a darkened room - best backlight I've found).
* made a wedge with two more straightedges spaced 2 mils apart at one end, so I can see what light shows through under a straightedge at various gaps. (0.1 mil shows light. My straightedges go together nice and dark - matching to better than 0.1 mil).
* made a 12" x 12" surface plate. I won't go into detail in this post, but I glued two 1" slabs of bluestone together (total cost $14), learned from experience (mistakes), and ended up with a plate that shows dark under straightedges put down anywhere in any orientation.
* bought three cheapo 6" speed squares and worked out the technique for squaring them to one another, which was an interesting problem. Now they seem to be good to about 0.1 mil too. (One was out a disgusting 11 mils!! I mean, really.)
So -- how flat is the plate? I've seen references that a straightedge might not tell you how flat a surface is, but can anyone give me an example of a surface that fools it? A twisted surface (imagine taking a capital H and twisting the two parallel strokes) shows flat if the straightedge is kept parallel to the twist axis, or at right angles to it. But held obliquely, it shows curvature gaps. I think I have a shop grade surface plate -- attractive pale blue color, too. I only worked it down to 1500 grit sandpaper finish, so it has a medium sheen, and it's sealed with grout sealer. It seems to be working.
BTW, I got a lot of experience trying to estimate small dimensions by eye, and it's amazing how your eye fools you. At the end of a long work session, you can get frustrated because those tiny errors start to look as big as potholes, so you think you aren't making any progress. Get a night's rest and -- hey -- they're much smaller!
