If your lathe permits, construct a rear tool post for cutoff work. It works a lot better.
Would you mind explaining why that would be?
Thanks,
-Ron
Thanks,
-Ron
I'm not sure I can give an explanation,but I have read a lot of claims that it is a better method for light duty lathes. I have used it on two different lathes, a 10 inch Atlas and light weight Grizzly and it works for me. One benefit is because the tool is upside down, the chips fall away.Would you mind explaining why that would be?
Thanks,
-Ron
I did a little searching and this explanation sounds reasonable too. Its from Practical Machinist forum.
"why a rear parting tool works better than a front tool you haven't included the real reason. Probably all of the reasons you give have some relevance, but the most significant is that the cutting forces on a front toolpost, whether or not a topslide is used, rock the toolpost down and towards the job, pushing the tool into the work - if the tool grabs, it dives into the job. The tool held in the rear toolpost is being lifted out of the job by the cutting forces.
The front toolpost gives positive feedback, the rear toolpost gives negative feedback."
An Italian lathe made in the '70, the Ceriotti, had a cut off vertical slide as extra optional.
You can see it here: http://www.lathes.co.uk/ceriotti/
