In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
holy cow, that's uplifting and depressing at the same time Just to think of all those years I spent obsessing about girls when I could have been learning how to machine!
so what's next? With chops like that only your imagination can limit you.
Thanks, the 10/22 stock build should be starting in a month or so. Not sure how I want to go about that yet. Might put it off a little if I'm not sure.
I missed my calling? I plan to go to a 2 year community college to get a bachelor degree then to a machining trade school. That is if competitive shooting doesn't get in the way.
Okay, did a little more this week. I made some taper shank drill bits for the tailstock and because the tailstock is a wide and short taper (think miniature 40 taper) I need a taper lock collar to hold the bits in the tailstock.
I did all the threading mostly by hand (turning the chuck by hand) because I was getting a bad finish. Plus I don't have to release the half-nut so it went faster and I had a lot more control.
After cutting threads.
And the cap/collar threads on
Here is how it fits together. The collar goes over the drill and pushes the taper into the tailstock ram.
Here is how it looks assembled. Runs true when rotating the tailstock ram. I can flex the drill just a hair sideways though because the taper isn't the best from boring bar deflection. I may cylindrical grind the taper. Probably won't though.
And a diagram of taper dimensions.
Think I should do weekly updates instead of whenever I get around to them?
