Here are my 2 tractors.
The Mc Cormick FU 237D
The IH 423
This two tractors were made in France. I don't know if this models did exist in US.
DAN_IN_MN > Yes, you re right. It slide a lot. But only with the 423. Because the Backhoe's force raise up the rear wheels without difficulties. And because there is no brake in the front wheels, the tractor is easily moved away. With his front loader, the 237 has not this problem. In the video I notice that the ground is soft to dig. No stones. In this conditions, I have no big problem even with the 423. But in my home the ground is much more hard with a lot of limestone.
However this chassis is not well adapted. Like I said above, I have to design a new one more appropriate. This one is not enough wide.
But for the moment, I keep this one, because I have a lot of new projects. I will made a wood grinder. The plans are ready to cut the sheet metal. But the taxes are fallen this week... And I have to wait 2 months before order the cutting (the taxes in France :angry:...).
I have another project which may interest you I think. I want to modify this antique lifter :
I want to install this mast on it :
(I had installed it on the 423 but it is very very dangerous so I quickly stopped to use it).
This mast lift at more than 5,2 meters. With a nacelle, it is possible to work at 6,5 meters from the ground. Interresting to work on the frame of my future shed and other works.
And I will made a dump to transform it into a dumper. The problem whit my backhoe is that it is not easy to approach enough the trailer in all the case to load it. So a dumper is easier to approach.
And the last modification is to install hydraulics brake because this machine don't brake at all. My 237 have the same problem and I have installed a car brake system on it. I will make the same thing on the lifter.
Here a few pictures more of the making of my backhoe :
Machining the blade (special steel called "creusabro" here) :
Welding the bucket :
Pre heating of the blade :
Making of the front arm :
Painting
Bye
