T
TOOLMASTER
Forum Guest
Register Today
BETTER get some knee pads
Thank you very much cathead, i like your thinking!!!MIke,
If you are into multi-tasking, you could use the AB-ROLLER to make tortillas or lefse or possibly gold leaf with a little modification.....
Keep thinking outside the box..................(KTOTB)
Thanks for looking Ray, you got me laughing here!Pretty sure that in recent times, if I were to use that thing, the bar might not be big enough in diameter or the bearings might fail.
thank you very much for reading, the shrink tube seemed better than bicycle handlebar wrapGreat Job! I love the shrink tube idea.
Hi Daryl,In the interests of over-complicating and overbuilding I'm wondering if changing the diamter of the wheel changes the effort or strength required.
I'm guessing that the smaller wheel requires greater flexibility as it would put your shoulders closer to the floor.
How about adding back-gears or intentionally increasing the drag requiring you to push or plow when going out.
Perhaps even a clutch which would have separate in and out drag intensities.
Would a very very narrow wheel require more balance?
Daryl
MN
Thank you very much Bob, i was trying to use materials that i had on hand.I have to say I really like your "run flat" wheel barrel tire and axle. Nice job. Might be a bit tough in sand or mud, but should be fine on hard pack or pavement.
