- Apr 30, 2012
- 2,401
Could you guys recommend the metal or raw materials for making a scribe. I bought a used starrett surface gage missing the scribe. I need one... can you order them separately? Are they expensive?
the best i have found is a broken carbide endmill reground to a point the 1/8 burs work well and will hold an edge forever. it you need a certain diameter use the shank of a broken drill the proper size, heat to red and quench then grind to point. drill shanks are soft so you have to heat treat.
steve
