Hi,
I made these adjustable feet a while back and since Nelson wants some more articles, I thought I would post them up.
There made from materials I had on hand. I started out with only making 6 for the lathe because I have just finished moving it, and can't bolt it down were it is. Then I decided to make the 4 for the mill and 4 for the shaper while I had the lathe set up to do them, and saves doing them latter.
They are made from 50mm mild steel I had, cut to around 25mm in length on the band saw, with a 14mm hole drilled in the centre on the lathe then shaped up to what I thought looked good.
I cut up some old chemset thread rod that I had as well. That why 6 have a hex in the end.
The thread rod is metric 16x2mm machined down to 14mm diameter on one end 15mm long to go into the bases. I used the vise to press them together and then plug welded them from the bottom.
The machined recess on the sides were the black is, is only to give the look of factory machine mounts, these are made of one piece of 50mm, not 2. For a lathe your better off with solid mounts to stop movement after it's leveled.
The other pictures show the feet the feet installed on the extension bases I made when I got the lathe. The Chinese just don't make these lathe stands high enough, so I made the extensions out of 75x75x4mm square tube cut down the middle to make C sections.
Dave
Dave
