In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
We are off and running. I need to bore in 3 inches on that back end of the mandrel. It sticks out of the 4 jaw 5 inches. With the help of an old friend (Steady Rest) it will hold stable to accomplish the boring operation. It will also be needed when the part is reversed in the chuck to fit the 5C collet.
Yes, I built that one. It is documented somewhere on this Forum. The one that came with the lathe was way too small to turn the journals on crankshafts using a cathead. Found it. :rofl:
My 12" Logan didn't come with a rest. And I watched oBoy, for months, to find a used rest that would fit. When this 13" clone set showed up, at a good price, I bought it, knowing I could easily cut the height down by 1/2" and weld the cast iron. Fits the ways, exactly.
