• Welcome back Guest! Did you know you can mentor other members here at H-M? If not, please check out our Relaunch of Hobby Machinist Mentoring Program!
  • In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Winner Home Grown Cutter Grinder
  • Thread starter Thread starter Bill Gruby
  • Start date Start date
Status
Not open for further replies.
The locking surface on the 30 degree tilt is worn badly. It is worn below the pivot arbor and cannot tighten properly. I will reface it flat and build it back up using a bronze washer.
"Billy G"
Spotfaced to +.065. Now to make the washer.
"Billy G"
New face washer and lock is 100%.
"Billy G"
Yes Dan, that is it's purpose. If the splash becomes too much, plexiglass sides will be added. As you see it, it's 1 inch deep.
"Billy G"
Hope I'm not hijacking your thread, just hoping to give you some more ideas
I built a single lip cutter grinder fashioned off the Deckel ones. Still need to make some holders for end mills and such but for now works for lathe and shaper tools and D bits.
Used a tread mill motor to dial in 3600 for the wheel shown or 5000 for a diamond faced wheel I have.
Greg
Greg
Greg
Simply brilliant! What did you start with? How much did you build yourself? Do you have a build thread?
Tomorrow is another day. I have to make a travel stop to limit the movement of the work holder across the wheel. This was one of the parts that is missing.
"Billy G"
Wow bill, I figured you had posted this and it was gonna be a nice slow build I could follow along with. Next thing I know you're halfway done with the dang thing ;) Looking good in any case, and I'm excited to see the end product.
Status
