I haven't looked, but actually I'd be a little surprised if you could wobble broach a d-hole. Rotary broaches are pretty limited on the amount of material they can remove to bring in the desired profile. A d-hole would have to be drilled just under the flat to centerline dimension, and on most, that would leave quite a bit of material to remove. I have my doubts. I've done and seen a good bit of wobble broaching, and there's a little more to it than meets the eye if you want the tooling to last, and make any time on the parts. Also, the finish of the flats (or whatever shape) isn't all that slick, at least in the materials I've worked with. I've done D-2, 4140/42, 660 Bronze, Aluminum Bronze, and BeCu. It's a slick process, no doubt, but it's hardly prefect.
