Monk,
Beautiful job, well done and thanks for sharing.
I too have to echo Greg in rpm speeds, It does seem a bit too fast. I don't want to take anything away from what you've done as it's a very beautiful little machine that you made.
You certainly have options on what you can do, I see a couple of things I can suggest. I'm mostly thinking out loud and just ideas. Your motor is very close to the driven pulley which effects torque and how small of a pulley you can go on the drive side. Luckily these filers do not need much power. I would suggest swapping out your current 4L (or 3L) belt for an AX belt; you'll get increased torque performance with your tight distance and small radius, especially if you go with a 5" pulley that will incur less contact area on the 2" pulley. I believe they make 1.8" pulley but not sure what torque rating they have, it's exponentially less as you go smaller/bigger ratio, the AX belt will certainly help with that.
Another option that I think would match very well with the beautiful work you've done (and only an idea) is to use to a small high torque brushless DC synchro motor that are now being utilized on sewing machines. They're variable speed, with even torque at all speeds and have a really small footprint and there priced well since so many are being made for the sewing industry, there getting rave reviews by the ones who are utilizing them in tool shops. The only factor is that they have a remote elec. box for the controller and it has mechanical lever to control speed to use your foot but with your skills, thats an easy & quick mod to change into a small dial speed knob. Having the speed control and constant torque, you can dial in the perfect speed for the material your filing, there also very quiet & super smooth compared to a regular motor.
I believe Pine Grove adopted their large casted flywheel design like what is seen in the sewing world to give the file more torque with the large mass of weight turning in the flywheel to keep it moving smoothly when applying pressure against the file. They really use this with sailmaker sewing machines.
Again, well done and you have a very nice machine there and impressed with it. Cheers
