It's kind of hard to bolt a random supercharger on an engine all willy-nilly and expect to get it to idle, let alone handle transient throttle movements without things going boom somewhere. Knowing the displacement and drive ratio is just scratching the surface for balancing the thermodynamics and fuel/spark requirements of the system. A developed boost map (adiabatic efficiency from pressure ratios and volumetric performance) is the minimum info required to tune a forced induction system. You could put one of these on your riding lawn mower and tune it to run okay at one spot in the throttle's sweep by trial and error, but if you want to run that supercharger "wet" first invest in some kevlar undies to protect your peanuts!
