Looks like your going to need to modify your clamp. It may need a toe to keep it level and it may need to even be longer to go flat against your rack gear. Don't think there's enough room on the edge beside the rack. Others here may have other ways of doing it . Take a good look and figure it out.
Now, can you glue a couple of pieces of 1/4" key stock on the top of the clamping bar, One on each side of the screw? or maybe 1/8 key stock? It looks like 1/4" stock would make the screw too short. Play with it and see what you can do to make it work.
Yup, the first pic is upside down. The profile of the stop that contacts the ways does not match your lathe. Cannot tell if you can recut it to fit but maybe that would work.
Well, I rotated the photo 180 and realized that what I would call the stop screw heads are what contacts the carriage (all of the ones for Atlas are made the other way around). So it isn't a mirror image as I first thought. But you are correct. It doesn't come close to fitting the V-way. Must be for a larger machine with a taller "V".
You can look on the Rockwell Delta Yahoo site and download a sheet that shows the part numbers. It will tell you which lathe the part will fit.
The sheet indicates a part number 25-655 for the RD 11" lathe.
