Hey guys-
Recently I was lucky enough to be able to snag a pretty clean HLV-H for a song. The downside is it wasn’t under power and hasn’t been for over a decade, and it’s 440v. I have 220 3ph in my shop via a 10hp rotary converter, the plan being to run a transformer between the converter and the machine. When I opened the panel I found a contactor lying loose inside, apparently having been bypassed at some point. I’m a bit out of my depth with this panel... can anyone in the know tell me what function this contactor has? I’m trying to plan out what I need to do before I get it under power without letting the smoke out. I’m assuming the bypass is there for a reason (bad contactor?)... do I try to run it as-is, replace the contactor, test it somehow, something else entirely?
