- Nov 16, 2012
- 5,596
Perhaps powering it off then, touching it to ground before handling is something to consider. BTW: 48 volts is the known threshold of safety. You can put your hands across a 12V car battery but with 48 volts, you're tempting fate. Welders usually have an open circuit voltage below that threshold and are often in the 20 to 30 volt range. There is also something called Capacitive Discharge. The human body can be a store of built-up charge or depending on conditions, a void of charge. The effects are additive so, touching a charged probe (depending on positive or negative electrode) can give you a zap much larger than the OC voltage of the welding unit. It's that zap that can trigger an arrhythmia because the current is momentarily traveling through all parts of the body until voltage equilibrium is reached.
Ray
PS: I used to make/design invitro fetal heart monitors. Here IS some advice. Don't handle a live TIG probe. )
Ray
Good info. The old Miller Econotig is always hot- no foot control, so it's searching for ground more than I thought.
