First some very basic info about EMI/RFI and Emissions:
EMI: Electromagnetic Interference -These are magnetic flux waves just like from a magnet and can be very strong. Strong magnetic waves can produce voltages by induction into any metal object (typically a coil of wire). These do not directly interfere with radio signals but they can mess-up radio equipment. Magnetic waves travel through the body harmlessly unless they are pulsed waves and you have metal inside you.
RFI: Radio Frequence Interference -These are electrical radio signal frequency waves. They are very, very low voltage waves which can (for practical discussion) only be detected and modulated. They can mess-up radio signals. They are typically absorbed by the body harmlessly or just pass right through (depending on frequency). They tend to reflect off of metal objects. Extremely strong RF, can theoretically damage humans but, it takes one heck of a source for that to happen (i.e. military grade radio transmitters).
Conducted Emissions: These are stray signals traveling down a wire or conducted path (possibly a human). Crummy power supplies actually send a signal back through the power cord and into your house grid and this can cause TV's etc to misbehave. This is how Christmas light controllers work as well as "Ethernet over Wireline" computer connections. Sometimes strong magnetic waves are induced into power cords and actually screws-up the appliance in-question. Those are both examples of Conducted Emissions.
Welding produces all three of these types of energy.
NOTE: I am NOT giving medical advice here. That said, there are several types of pacemakers and monitors. Some have external wires inside the chest cavity and this exposes them to magnetic induction. There are wire-less types which are less vulnerable but, the type you have depends on the medical condition being addressed. The vulnerability factors are taken into consideration in the unit and numerous precautions are taken to provide immunity from interference even from extreme sources. Even still there are risks due to interference. The real problem however is conduction interference. Anyone with a heart fibulation (or monitoring) device should not (in my personal OPINION) be welding because, direct, conducted exposure interferes directly with your nerve paths. This is NOT good for anyone with serious medical conditions.
As far as the blue spark from your TIG torch. -You are possibly handling the electrode while the unit is still in the ramp-down stage or, it is malfunctioning. Get it fixed or at least, ground it out to earth before handling it.
The grounding I originally mentioned was not table grounding. I was speaking of grounding the frame of the welder enclosure unit. The metal frame acts as a "Gaussean" shield and collects much (but not all) the EMI/RFI radiating from the internal switching power supplies or coils. Grounding the frame takes all that energy and releases it back to mother nature instead of radiating in free-space and screwing up someone's TV/Radio or pacemaker.
Once again, I have expressed my personal OPINIONS based on good knowledge of this area and I'm NOT giving advice on what anyone should do.
Ray
Back to what Benny said; When I stand away from the ground cable and loosen the TIG collet for adjustment, it will still zap a blue spark between finger and tungsten. Would a grounded table prevent this 'broadcast' of HF to any local ground source?
