- Oct 20, 2014
- 159
Criticism of what I describe here is WELCOME!!! Please, lets dissect this, tear it apart, and make it better.
The good news is: I think I am getting control of diameters, +/- 0.0001" (tenths), on my ancient, worn out Atlas 10F lathe.
I also learned something very important about manual lathes today. That alone is almost more important than being able to cut within tenths.
Heres how I did it, and that special thing I learned:
Notice how the handwheels are graduated in 0.001", and the space between two graduations is about 1/32"? WAY too small to control tenths, accurately anyway. Yes, you can approximate. But seems kind of strange to me that a lathe would have handwheels that coarse. Im sure when even this low grade Atlas lathe was brand new it could cut in tenths reliably. Hmm. Actually..come to think of it the Hardinge HLV-H extreme precision lathe I used at work long ago was also in 0.001". So how the heck is anyone supposed to work in 0.0001"?
Even a DRO or dial indicators wouldn't really help, because you'd still be stuck trying to turn that handwheel just that TEEENY amount!
Well, thats where the compound tool post comes in. It will let you magnify its handwheel by MORE than you would ever want!! Yes, you can turn the handwheel 100 ticks and it will only move the cutter forward by .001" if you want!! So essentially you have made it so that each handwheel graduations of 0.001" actually means 10 MILLIONTHS of an inch! Now tenths become cake!
The idea behind this is to just rotate the compound tool post so its a very slight angle instead of parallel to the spindle axis. To be clear, "parallel" to the spindle axis would mean that turning its handwheel would move it towards or away from the spindle.
Now think about that, if its only moving towards or away from the spindle, its not moving the tool towards or away from the work at all, is it?
So if you put it at a very slight angle, it WILL move the tool towards or away from the work. Turns out that at around 84 degrees, for every 100 thou of its handwheel, it moves towards the work by only 10 THOU! Now each tick is 0.0001"! Tada! And if you want you could theoretically reduce that angle even further and probably multiply it by ten times again!
REALITY CHECK
-You are still limited by the accuracy of the threads, ways, etc.. You cannot precisely move the tool by 10 atoms just because you have the slide at an angle. But where that limit of accuracy is is now something you can move on to dealing with, instead of trying to turn a handwheel by some teeny amount.
-The angle readings on the compound tool post are not very fine. You should get the angle to approximately where you want and then do some test cuts to confirm the new tool post handwheel versus actual increase in cut distance, and then do some arithmetic and calculate how many thou you need to turn the handwheel to get what you want. If you dont have a tenths micrometer, now you have an excuse to buy one!!
-You will likely need to rotate your toolpost so the tool is again perpendicular (or whatever you need it to be) to the work, since you are rotating the tool post.
RESULTS!!!
So...does this work or not? The answer appears to be YES!
I spent the last couple hours experimenting to see if I could really make reliable cuts in one shot based solely on the handwheel.
Material: 303 stainless
RPM: about 800
Cutter: carbide TPG322 in a very rigid insert holder and tool post
Lube: none
Diameter of workpiece: about 1/2"
Workholding: 4 jaw chuck. Stickout about 2".
Feed: automatic, about 5 thou per rev
Machine: Atlas 10F from 1944
Cutting notes:
All done in three passes. First two were easily seen. The last pass was BARELY visible taking place..I'm not sure if it was doing anything or not. I have very good vision up close and could just barely see the "line" moving by getting up real close. And to be clear, I made NO adjustments to the handwheels between passes. I just turned the motor off, used the carriage handwheel to move the tool back to the beginning of the cut, and then powered it up and repeated the cut.
I made many test cuts. Some of them came out right, some did not. A few came out about 1 thou off!! But I think I have it figured out now.
The final two cuts I made came out within about 0.0001" of where I intended. I think what was happening with the cuts that didn't work out was that I was not taking deep enough cuts. And I also screwed up the math a few times since my calculator was dying and I couldn't read it. I would get your notepad and calculator handy and keep a log of what you do so you can figure out how deep you need to cut and what RPM/stickout you need to do, etc..
FINAL CUT #1:
Target radial reduction: 0.0117"
Actual radial reduction: 0.01175"
FINAL CUT #2
Target radial reduction: 0.0107"
Actual radial reduction: 0.0108"
(the pic shows the incremental change in diameter)
Please join in the fun and report your results!!! You will need an accurate tenths micrometer to play along. The one I'm using was $30 from horrible freight!
REALITY CHECK
RESULTS!!!
RPM: about 800
Lube: none
Cutting notes:
FINAL CUT #1:
FINAL CUT #2
