Since it's been over two months since I've updated this...
I've been tinkering with the Hendey off and on, but haven't accomplished much. It was in my shop up until the middle of December, when I realized all the cold, wet weather we've been having has caused condensation in the shop. This led to surface rust beginning to show up on the ways...
The week before Christmas, I moved the lathe into my basement, where it is warm and dry. I've had to re-derust, clean, and oil the ways.
I began assembling the taper attachment, and ran into a problem. The gib adjustment screws wouldn't thread through the holes in the slide. They are non-standard 5/16 x 20 TPI threads, so I had to find and order a tap. I used the tap to clean out the holes, which fixed 4 of the 6 holes. The other two still won't thread in deep enough to contact the gib.
After fooling with it for an hour, I finally determined that the heads on the screws are binding against the sides of the counterbore on the holes. Either the heads aren't concentric with the screws, or the counterbores aren't concentric with the threaded holes...
I'll probably fix it by skimming 0.005" or so off the screw heads... that would be easier than trying to open up the counterbores.
This morning, I began working on the cross slide lead screw assembly... it has to be installed before the taper attachment. I've mostly assembled it, but haven't installed it yet...
and again, I've run into a problem...
The large screw that fastens the lead screw nut to the cross slide has a 1/4-24 set screw in the center... it is removed to oil the lead screw. This set screw is rusted into the large screw... rusted solid...
My plan is to soak it in evaporust for a couple of days, then soak it in Kroil for a few days... if that doesn't work, I may have to drill it out. Or I could simply machine a new screw...
-Bear
