I am new here so let me say thanks for the great amount of info on this site. secondly sorry for my poor typing skills.
I just bought a rockwell 11" lathe from my friends dad. when picking it up he used chains and a front end loader to load it onto my trailer. i noticed after he set it down that he had one chain wraped around the table and the lead screw. after i got it home and installed it i checked the lead screw and it is bent slightly. when using the automatic feed in either direction, at any speed, cutting any material it leaves small noticable lines usually about 3/16" apart from each other all the way down the length of the work. whil cuttin i have noticed that the timing of the lines is exactly one line per revolution of the lead screw.
I tried adjusting the half nuts, went through with the manual and adjust everything to try to eliminate any possible problems. it is still there. could a slightly bent lead screw cause this or should i be looking else where?
