- Jan 24, 2018
- 11
Thanks mksj, I'll check those out. Im currently doing research on different inserts for aluminum. I'm ashamed I just used whatever insert I found and didn't put anymore thought into it. Insert choice is confusing to me, I guess WNMG are used for finishing? I suppose having a .030 nose makes sense for that? 80 degrees seems more rigid for roughing though? I'd assume smaller nose and smaller angle would mean more prone to breaking in deep cuts but what do I know... What is the best shape/nose/angle for turning aluminum at about .100-.150 DOC? And with these inserts being rated so high as far as SFM goes how can a 20+ year old manual lathe keep up? Do I just punch it and run at 1000 rpm and X amount of IPM? I think I baby the old girl a little as I'm not sure what she'll do at the highest rpms and feed rates it can get to {max 1500 rpm}. Also would say ceramic hold up better to heat as I'm not using coolant of any kind during these heavy cuts.
Sorry for all the noob questions, I spent 3 years in machining class during high school and graduated a 2 year Machine Tool Technics program at a technical collage and feel like I retained less then I should've. They focused heavily on CNC. Now it's been oh 8 years since then and I really never used my degree. I'm a machinist at a little mom and pop factory with all manual machinery and before getting back into the industry haven't touched one since 1st year of tech school. I remember a lot but want more.
