- Nov 14, 2014
- 851
Hello all,
Note: I went back out and figured out how the assembly goes back together - found a couple of threaded nuts in a box of loose parts that fit the lead screw - ran them in tight against the inside of the casting so no play with the lead screw. Also reversed the auto feed lever to hold the arm engaged . So looks like good to Go. love the simplicity!
Tomorrow will work on connecting the drive linkage to the auto feed...
Having a couple of problems figuring out how the table assembly goes back together on my Burke #4. I purchased the machine partially disassembled so don't know if any parts are missing.
My first problem is how to secure the y axis lead screw against the bushing, so it pushes and pulls the table along the knee when one turns the hand wheel. In the first photo, the leadscrew has a thread pattern, but no sign of a shoulder, pin, or method to hold it in place after inserted into the bushing in the knee. Of course the army Burke manual shows no internals...
Second issue, is how does the auto feed lever on the right end end of the table hold the the x axis leadscrew gears in place to feed the table? Here are the parts I have installed - in what I assume are the correct locations...
Iam off searching for an exploded parts list, but so far no success...
Thanks much for any suggestions anyone can offer!
Regards
Glenn
Regards
Glenn
