Help - What are these?
The two items on top shook a brain cell. After some research. I believe those two rods with cones are called "steeple headed rivets" used for fabricating boilers. Mark
the two cone shaped tools on the top would be nice to peel off the wax on the cone part---they could be coated with diamonds---I have several with 1/2" shanks that are diamond coated and were used to bevel inside ends of fiberglass tubes---if they are just smooth then they may be used in a press to flare tubing-----Dave----see--I wasn't fibbing about having them---these have 1/2" shafts and are 2 3/4" long and are diamond coated DSCF0001 (2).JPGDSCF0003.JPG
I did peel one off, and it's a smooth as a baby's butt. Ground and maybe polished all over. It does have a recessed cone in the end as for a center, about 1/8".
If it were a flaring tool, would it require that level of finish?
yes possible in a big press ----I am sure if it has a center drilled in the cone it is designed to be made very precise and if it is used in flaring tubes you would want a very high level finish---you could make a live center for your lathe for use on large tubes if you have a good sized lathe-----if nothing else they could be stored with your arbor or bench press tools---------------Dave
Would the bottom one be part of an eye piece from a centering scope?
David
