- Dec 20, 2012
- 9,408
Most of us use grease on the rear side of the scroll and the pinion. Use a light coat of oil on the front of the scroll, the jaws and jaw guides. You do NOT need a lot of oil on these parts. Personally, I use Super-Lube grease and oil for this job.
When you first turn on the lathe after a clean and lube, all the oil that I said not to put in the chuck will come flying out so put up some kind of absorbent shield in front and behind the chuck to catch the slung off oil.
