Help On the Threading Chart on a PM1130 Lathe
sportfan
Sep 18, 2021
38
The thread chart could be in Latin as far as I'm concerned. I just don't get it. I've threaded on bigger lathes but, never on one where I had to change gears. When I look at the gears that came on the machine, I don't see that combination on the chart. If someone could simplify it to top inner, next down inner and outter,next down inner and outter say for a 16tpi set up maybe I'd get it. Thanks for any help,I'm still learning (or trying to).
The manual doesn't appear to be available on the website. Can you post a pic of your threading chart?
The resolution of the pic isnt very good, when I zoom in on it, the numbers are blurry enough that I can't tell one number from the other. This is what I can see:
So, it looks like for 16tpi, you need the gears arranged (top)60 tooth on -40-30-(bottom)60, (60 tooth drives the 40, which drives the 30, which drives the bottom 60 tooth), but all the shafts appear labeled Z1, due to the blurriness
It copied really clear on my computer. This may work for you, save it to photos and then enlarge it.
I think I've got it. I'll go give it a try, thanks for your help.
