- Apr 14, 2014
- 3,533
I forgot to comment about the chuck in your original post. Taking a look at it I would prefer a different style. The one you have chosen requires 2 sets of jaws. One for holding on the outside of a work piece, and a second for holding on the inside of a work piece. I have no problem with the way it functions (I do have several of this style), however my preference is to have a chuck with replaceable top jaws. This style only requires one set of jaws. They are unbolted from the base jaw and turned around for inside holding.
Here's a link to the style I'm referring to:
http://www.ebay.com/itm/6-4-JAW-SEL...300499?hash=item4841a9ec93:g:Aa4AAOSwTapV46Z1
The major advantage is that there is only one set of jaws. There's nothing to store in that "special place" until needed. In time you'll forget where that 'special place" is and spend more time looking for the jaws than changing them out. Also if in time you acquire more chucks you'll have to sort and identify which jaws fit which chucks. In addition I believe there are at least 500 or more different design of this style jaws. Finding a replacement could be a nightmare. As a side note I "lost" a set of inside jaws for several months. Finally deciding I must have inadvertently thrown them out I broke down and purchased a new chuck. I didn't have the new chuck 3 weeks when I stumbled across the "special place" where I'd stored the jaws.
The replaceable top jaws on the linked chuck are known as American Standard design. There are dozens of vendors that make replacement hard jaws and also soft jaws. While hard jaws are expensive at least they can be replaced. Soft jaws on the other hand are inexpensive. Some are as low as $50.00 a set. In addition I don't know of anyone that even makes soft jaws for the style chuck in your picture. I do have one set of soft jaws for an older chuck of that style. This is an older Union brand chuck that was ordered new with a second set of hardened outside jaws. They were then cut ground, and fitted with bolt on soft top jaws. I'm not aware of any manufacturers today that offer additional replacement jaws when ordering a chuck.
